[Qgis-user] failed to add WMS layer
Stewart Holt
stewartbholt at gmail.com
Thu Aug 1 11:08:12 PDT 2019
I use USGS WMS and WMTS layers. At some point in the recent past the WMS
layers stopped working. I am almost sure they have worked in QGIS V3. I
usually use WMTS because of the speed, but for final publishing, I have
seen some cases where a corresponding WMS layer is higher definition, so I
would like to be able to use it. Also the long timeout while starting the
project is unfortunate and I don't want to delete the WMS layer. Here is a
WMS layer which fails:
https://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WMSServer?request=GetCapabilities&service=WMS
And a corresponding WMTS layer which works:
https://basemap.nationalmap.gov/arcgis/rest/services/USGSTopo/MapServer/WMTS/1.0.0/WMTSCapabilities.xml
On the failing WMS layer, I have removed it and added it back. When I test
it I get a message saying that a get capabilities request has failed. I
hope someone who might be able to figure out what is going on can give this
URL a try.
Thanks,
Stewart
On Thu, Jul 25, 2019 at 12:20 PM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Thu, Jul 25, 2019 at 12:34 PM Manuel Fernandez <mfc652000 at gmail.com>
> wrote:
>> Hi, everyone. I have a problem
>> When adding a WMS layer, I get this error:
>> Capabilities could not be downloaded: Capabilities download failed:
>> Connection closed.
>> It used to work.
> Can you provide the WMS address?
> BTW, I've recently hit a similar issues and it ended up being an upstream
> QT issue: https://bugreports.qt.io/browse/QTBUG-76821
>> Thanks in advance
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190801/df0d5d59/attachment.html>
