[Qgis-user] Adding PostGIS Layer (Query Before Load)
Jürgen E. Fischer jef at norbit.de
Tue Aug 6 00:33:03 PDT 2019
Hi Peter,
On Mon, 05. Aug 2019 at 22:29:19 +0000, Peter Borissow wrote:
> I looked at the Data Source Manager (Layer -> Add Layer -> Add PostGIS
> Layers...) but I don't see any filtering options there and the app hangs when
> I hit the "Connect" button.
Did you enable "Use estimated metadata" on that connection?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190806/3e8519d5/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190806/3e8519d5/attachment.ksh>
