[Qgis-user] Lat, Lon Tools now Supports snapping when copying coordinates to the clipboard.
Paolo Cavallini
cavallini at faunalia.it
Fri Aug 16 23:27:16 PDT 2019
Thanks Calvin! Sooner or later at least some of your work should go into core, I believe.
Cheers.
On 16 August 2019 21:36:09 EEST, C Hamilton <adenaculture at gmail.com> wrote:
>I wanted to let everyone know that the "Copy Latitude, Longitude" to
>the
>clipboard in Lat, Lon Tools now supports snapping to existing vertices
>of a
>vector layer. This is enabled when snapping is enabled in QGIS from the
>"Project->Snapping Options..." menu.
>When snapping is turned off the "Copy Latitude, Longitude" functions as
>normal. When snapping is enabled and hovering close to a vector layer
>vertex or segment as specified by "Snapping Options" then the "Copy
>Latitude, Longitude" tool will copy the precise location of that vertex
>to
>the clipboard. A small square is drawn around the vertex to notify the
>user
>that snapping is enabled.
>Enjoy,
>Calvin
Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190817/e714f4b5/attachment.html>
