[Qgis-user] failing to do clip
Raymond Nijssen r.nijssen at terglobo.nl
Sun Aug 18 00:28:06 PDT 2019
Hi Boaz,
On invalid polygon layers, I'm usually more lucky running the buffer
algorithm with a buffer distance of 0.
Regards,
Raymond
On 17-08-19 22:57, Boaz Bar Ilan wrote:
> Ok, thanks.
> I tried to do it and it didn't work
> boaz
> ‫בתאריך שבת, 17 באוג׳ 2019 ב-23:29 מאת ‪DelazJ‬‏ <‪delazj at gmail.com
> <mailto:delazj at gmail.com>‬‏>:‬
>     Hi,
>     As suggested by the error message, I'd say in the Processing
>     settings, ie menu Settings -> Options -> Processing -> General.
>     That said, finding the invalid feature or running the repair
>     geometry algorithm beforehand could be a better solution than
>     disabling anything related to the invalid geometry.
>     Regards,
>     Harrissou
>     Le sam. 17 août 2019 à 21:37, Nicolas Cadieux
>     <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>
>     a écrit :
>         Hi,
>         I’am not sure that option is actually in QGIS... (never found
>         it). Maybe try to find the invalid geometry using the various
>         tools? Look under processing for the tools.
>         Nicolas
>         Le 17 août 2019 à 15:07, Boaz Bar Ilan <boazprosie at gmail.com
>         <mailto:boazprosie at gmail.com>> a écrit :
>>         hi
>>         im trying to clip two layers ans get the message
>>         Feature (89595) has invalid geometry. Please fix the geometry
>>         or change the Processing setting to the "Ignore invalid input
>>         features" option.
>>         **//___^
>>         where is this option ?
>>         thanks
>>         boaz
>>         _______________________________________________
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
