[Qgis-user] How to shorten this in Field Calculator
Willem Korevaar
wereldvak at gmail.com
Wed Aug 28 04:58:02 PDT 2019
I would like to shorten the following proces (= workaround) of calculating
a simple Rs (Spearman Rank correlation) in the Field Calculator .
https://drive.google.com/file/d/1vuW50nm1h4LduaAO01ThO6Nv-VXUGBo9/view?usp=sharing
[image: image.png]
and as an example:
[image: image.png]
Its about two columnsin the table (X-Y in the example ) : P_00_14_JR (age
0-14 in %) and P-N_W_AL (people from outside W-Europe in %).
I know that it can be done with an R- script, but as I m working with
students and I want to show them how the formula works and R is not working
anymore on the schoolsystem I tried a workaround. It works, but there are
too many steps.
My workaround is in 2.18.9 :
1. using the plugin Sort and number and ranking both columns. So two
more fields : r_014 and r_nw (rang x and y)
2. make kolom 6 ((x-y)2) using Field Calculator:
( "r_0-14" - "r_nw_ll" ) ^ 2
3. create new field in FC named RS:
1- ( ( 6 * ( sum( "kolom6" ) ) / ( ( (count( "BU_NAAM" ) ^ 2) * (
count( "BU_NAAM" ) ) ) - count( "BU_NAAM" ) ) ) )
In which 'BU_NAAM' = n (number of objects in this case names of
neighbourhoods in Den Haag) but this one can be any other fieldname.
New fieldname = RS and with 'Real' and precision 5
4. in this case Rs = 0,488 which means a little correlation
(I know that there should be no ties in the values, but that would make
the proces more complicated in case of
Is there a way in the FC I can do it in less steps?
This is the link to the table used in QGIS and the Rs formula in the
example:
I hope this all wil make sense :-)
Gr
Willem Korevaar
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190828/a459203e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190828/a459203e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190828/a459203e/attachment-0003.png>
