[Qgis-user] Print Layout Options
Phil Wyatt
phil at wyatt-family.com
Thu Aug 29 22:05:46 PDT 2019
Hi Grant,
Mmmm, maybe use the map item extents and a data defined override (if the
layer has fields for the extent?). A few tips in the link below.
https://gis.stackexchange.com/questions/267565/qgis-print-composer-set-map-f
rame-to-map-extent
Also, is this a one off map or are you also contemplating an atlas from lots
of maps with different aspect ratios?
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
Grant Boxer
Sent: Friday, 30 August 2019 11:12 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Print Layout Options
Is there a way I can snap a map window in a print layout to fit a layer
extent? For example I want the print layout window to fit the extent of a
map (e.g. published 1:100k series map) so that the coordinates go outside
the map frame without white space. Any thoughts?
Grant Boxer
Perth, Western Australia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190830/ac71a627/attachment.html>
