[Qgis-user] Handle local layers in resources folder when project saved in PostgreSQL
Jorge Gustavo Rocha jgr at geomaster.pt
Thu Dec 5 04:16:07 PST 2019
In my setup - using PGSERVICES - all vector, raster, styles and projects
are stored on database. This is my preferred way to organize the data:
on a database. QGIS Server also takes advantage of this setup and
publish the projects directly from the database, using the rasters (in
db or out of db rasters).
The few things I'm not sharing on the database are SVG, layout images
and fonts.
There are problems with Postgresql/GDAL access to Postgresql, but if
using PGSERVICES it works.
Best regards,
Jorge
On 05/12/19 11:18, Alessandro Pasotti wrote:
> On Thu, Dec 5, 2019 at 11:58 AM Yann Voté <ygversil at lilo.org
> <mailto:ygversil at lilo.org>> wrote:
>     Hi all,
>     I can't find a solution to the following issue, or a way to work
>     around
>     it: I have created a project with some PostgreSQL layers to edit and
>     some raster layers on local filesystem. I work on a Linux computer
>     and
>     have put the local layers into the pkg data path resources folder
>     (/usr/share/qgis/resources/local/raster.gpkg).
> Sorry but this is not a good idea, that path is usually not
> user-writeable and should not be used to store any user related
> information.
> But if I understand correctly what you were trying to do I'm afraid
> there is not a solution: the concept of "relative path" means relative
> to the project's storage path but that path does not make any sense in
> case of a POSTGRES storage (because POSTGRES is not a local
> filesystem-based DB in the same sense as GPKG or SPATIALITE are), so
> your file-system based asset paths are not (and cannot be) converted
> to relative paths because there is no project path we can relate to.
> This makes portability an issue if the project has filesystem-based
> layers (rasters in your case).
> There is no solution I'm aware of, storing rasters into PG is also not
> a viable option at the moment because support is currently buggy (see:
> https://github.com/qgis/QGIS/issues/30392).
> Cheers
>     I have also saved the project into PostgreSQL so that it can be
>     shared
>     easily. Other users work on Windows computers and have the same
>     rasters
>     under pkg data path resources folder
>     (C:/PROGRAM~1/QGIS3~1.8/apps/qgis/resources/local/raster.gpkg).
>     But when
>     they open the project, Postgis layers are loaded fine, but QGIS says
>     that raster.gpkg cannot be found under the /usr/share/... path.
>     I would expect that layers in the pkg data path resources folder are
>     saved with the inbuilt: prefix, but in fact they are not.
>     Moreover, it
>     seems that one cannot select "Relative" for saving layer paths, in
>     project properties, when project is saved to PostgreSQL. Looks
>     sensible
>     (what is the relative path to a PostgreSQL table ?), but then what
>     can I
>     do to share a PostgreSQL project with local layers ?
>     We all use QGIS 3.8.3.
>     Thank you for any advice !
>     Cheers
>     Yann
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3:   www.itopen.it <http://www.itopen.it>
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Jorge Gustavo Rocha* | Software Engineer
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
*g:*41.54094,-8.40490 | *v: *510 906 109
*a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191205/8cc0910b/attachment.html>
