[Qgis-user] Showing json text in atrribute widgets
    Bo Victor Thomsen
    bo.victor.thomsen at gmail.com
    Sun Dec  8 10:16:45 PST 2019
Thanks Matthias -
I was not aware that GeoPackage could handle json data. It works nicely
now after I have redefined the fields from text to json-text
Shall I open a ticket in GitHub about the missing option for creating
json-text fields in the create layer dialog for geopackage ?
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 08-12-2019 kl. 08:58 skrev Matthias Kuhn:
> Hi Bo,
> GeoPackage has support for JSON fields, meaning that text fields can
> be of JSON type.
> When you add a new JSON field (e.g via the field calculator) this type
> can be chosen and then the key/value widget should work.
> I just realized, that the JSON field type is missing from the create
> new geopackage layer dialog.
> Matthias
> On 12/7/19 7:08 PM, Bo Victor Thomsen wrote:
>> Hi list -
>> I'm trying to create a attribute form that would show  json key/value
>> pairs in an attribute form. The json data is stored in a text field
>> like this : '{ "one":"1", "two":"2",... }'. The dataaprovider is a
>> GeoPackage
>> I would like to show the json text field using a key/value widget.
>> However this option is always greyed out and can't be activated for
>> the text field.
>> I've tried creating a virtual field (type blob) where the value in
>> the virtual field was populated using a expression like: from_json
>> ("my_json_text_field") and other similar methods. However the
>> key/value widtget is always greyed out.
>> I'm aware, that I could create a Postgres database and put my data in
>> postgres table and getting it to work. However, that's not an option
>> in this case.
>> Is there a solution to this problem ?
> Qgis-user mailing list
