[Qgis-user] Exporting Google map image layout in pdf
Martin Weinelt
mweinelt at planiglobe.com
Tue Dec 10 06:21:57 PST 2019
Jean,
the area you are allowed to use in a layout is quite often limited to
smaller extents with services such as GM.
Give it a try with a map/layout that covers a smaller (really smaller) area
to make sure it's not a technical or usage problem on your side.
Martin
On Tue, Dec 10, 2019 at 3:08 PM jean Lukusa <lukusam at gmail.com> wrote:
> Hi all,
> Whenever I want to export m'y Google map layout map in pdf ,this later
> shows juste wihite background but not thé image of Google map .
> How can I solve this issue when using Sgis3.10
> Exploration and Mining Geologist
> +243(812156128/973741744)
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191210/9ce1756d/attachment.html>
