[Qgis-user] QGIS Server / GetPrint not rendering all the layers (XYZ Tiles for example)
Alessandro Pasotti
apasotti at gmail.com
Fri Dec 13 00:50:20 PST 2019
On Fri, Dec 13, 2019 at 9:17 AM Arnaud Vandecasteele <arnaud.sig at gmail.com>
wrote:
> Hi Etienne,
> Thanks for your help.
> As suggested, I change the config for :
> FcgidInitialEnv DISPLAY ":99"
> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL "0"
> FcgidInitialEnv QGIS_SERVER_LOG_STDERR "1"
> FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH
> "/home/arnaudvandecasteele/qgisserver"
> FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE
> "/home/arnaudvandecasteele/qgisserver/qgis-auth.db"
> FcgidInitialEnv QGIS_PREFIX_PATH /usr
> FcgidInitialEnv QGIS_OPTIONS_PATH
> The folder rights looks ok.
> ls -l
> drwxrwxr-x 2 www-data www-data 4096 Dec 13
> 08:45 qgisserver
> Unfortunately the error remain :
> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
> variable.
> variable.
> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
> environment variable.
> variable.
> ERROR: Auth db directory path could not be created
> Initializing server modules from "/usr/lib/qgis/server"
> "Checking /usr/lib/qgis/server for native services modules"
> "Loading native module /usr/lib/qgis/server/libdummy.so"
> "Loading native module /usr/lib/qgis/server/libwcs.so"
> "Loading native module /usr/lib/qgis/server/libwfs.so"
> "Loading native module /usr/lib/qgis/server/libwms.so"
> "Loading native module /usr/lib/qgis/server/libwmts.so"
> ERROR: Opening of authentication db FAILED
> QSqlQuery::prepare: database not open
> WARNING: Auth db query exec() FAILED
> As I understand the use of the authentification system in desktop mode, it
> is still a bit confusing for me when using a server.
> For example, I don't have any qgis-auth.db file on my server. Do I have to
> copy it from my desktop ?
no, you don't need to copy it unless you want to use the credentials you've
stored in it.
The DB will be created automatically if it doesn't exist when QGIS Server
process starts.
See: https://github.com/qgis/QGIS/blob/master/src/server/qgsserver.cpp#L245
> Thanks again,
> Best,
> Arnaud
> On Fri, Dec 13, 2019 at 11:37 AM Etienne Trimaille <
> etienne.trimaille at gmail.com> wrote:
>> Hi Arnaud,
>> It looks like a cache write issue.
>> QGIS_OPTIONS_PATH must be a directory, not a file path.
>> https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#qgis-options-path
>> I would add QGIS_OPTIONS_PATH too. And check that the profile is writable
>> for QGIS Server (www-data?). After the GetPrint request, I think you should
>> see the cache folder created.
>> This my config :
>> QGIS_CUSTOM_CONFIG_PATH=/home/etienne/dev/qgis/server_home/profile
>> QGIS_OPTIONS_PATH=/home/etienne/dev/qgis/server_home
>> QGIS_PLUGINPATH=/home/etienne/dev/qgis/server_plugin
>> Can you check that?
>> Le ven. 13 déc. 2019 à 07:25, Arnaud Vandecasteele <arnaud.sig at gmail.com>
>> a écrit :
>>> Distribution Ubuntu
>>> QGIS Server on server -> Version: 3.4.11+dfsg-2~bionic1
>>> QGIS Server on computer -> Version: 3.4.13+dfsg-3~bionic2
>>> I have QGIS Server installed on my computer and on my server. The same
>>> project is used on both. This project is very simple and contains a SHP
>>> layer and a XYZ OpenStreetMap layer. When printing the map (GetPrint) on my
>>> computer all layers are correctly displayed.
>>> The same operation on the server displays only the SHP layer and not the
>>> XYZ layer.
>>> When the GetPrint request is made on the server, the following lines are
>>> added to the log file:
>>> However, I have the impression that my configuration file is correctly
>>> configured:
>>> FcgidInitialEnv DISPLAY":99"
>>> FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb"
>>> "/home/qgis/qgisserverdb/qgis-auth.db"
>>> /data/owncloud-data/arnaud/files/GEOLAB/Transfert/webmapping-lizmap/QGIS3.ini
>>> <Rental /qgisserver>
>>> SetHandler fcgid-script
>>> FcgidWrapper /usr/lib/cgi-bin/qgis_mapserv.fcgi virtual
>>> Options +ExecCGI -MultiViews +FollowSymLinks
>>> Require all granted
>>> </Location>
>>> ErrorLog ${APACHE_LOG_DIR}/map-error.log
>>> LogLevel warn
>>> CustomLog ${APACHE_LOG_DIR}/map-access.log combined
>>> And the permissions look good:
>>> ls -l /home/qgis/
>>> drwxr-xr-x 2 www-data www-data www-data 4096 Oct 25 08:46 cache
>>> drwxr-xr-xx 2 www-data www-data www-data 4096 Jun 20 07:32 qgisserverdb
>>> Do you have any idea what might cause this problem?
>>> Thank you in advance,
>>> Arnaud
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> SIG - WebMapping - Spatial Ontology - GeoCollaboration
> Web Site
> http://geotribu.net/
> http://about.me/arnaud_vandecasteele
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191213/4c55d3d7/attachment-0001.html>
