[Qgis-user] Use form with checkboxes to alter a query?
Jorge Gustavo Rocha
jgr at geomaster.pt
Sun Dec 15 03:20:08 PST 2019
Hi Bernd,
May I suggest two tables?
You can create another table *control*, with just two columns: name and
active.
This could be filled with:
select distinct name, true from areas;
Your query would be like:
SELECT *
FROM areas
WHERE name IN (select name from control where active)
To change the virtual layer, you just need to open the *control* table
and click on the active column to set/unset as active. (You may have to
change the active column's edit widget to make it a checkbox).
I didn't test it.
Regards,
Jorge
On 12/12/19 17:12, Bernd Vogelgesang wrote:
> Hi,
> I have a layer with over 150 polygons, where 20 to 30 of them change
> their access status on a daily base. The information about the status
> comes in a quiet unstructured pdf, so there is no way to automatically
> read that in.
> At the moment, I query the layer through a virtual layer like this to
> show the subset of restricted areas:
> SELECT *
> FROM areas
> WHERE name IN ('a','b','c','l','p', 'x','y','z')
> It is quite a tedious job to fiddle in the names into the query string
> every time, so I wonder if anyone knows a way, how to connect a form
> with check boxes of those area names, so when I submit it,
> only the checked names will be inserted in that query.
> I'm quite sure that this should be possible somehow, but I lack of any
> idea where to start. Or maybe solve this on a complete different way?
> Cheers,
> Bernd
> Dipl.-Geogr.
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Jorge Gustavo Rocha* | Software Engineer
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
*g:*41.54094,-8.40490 | *v: *510 906 109
*a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191215/be6e8311/attachment.html>
