[Qgis-user] Couldn't load SIP module. ModuleNotFoundError: No module named 'qgis'
Frank Heuer frank.heuer at heuerhome.de
Tue Dec 17 13:02:44 PST 2019
Hallo qgis users
I need help with the new 3.10 qgis on my ubuntu Ubuntu 18.04.3 LTS
system. When I start qgis, I get an Python-errorbox showing, that the
SIP module could not be loaded. Because I run with german locale I could
only post the german message here, but its nearly the same as in
https://issues.qgis.org/issues/22029. Here is the original:
Das SIP-Modul konnte nicht geladen werden.
Die Python-Unterstützung wird abgeschaltet.
File "", line 1, in
Python-Version:
3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0]
QGIS-Version:
3.10.1-A Coruña 'A Coruña', ef24c52
<https://github.com/qgis/QGIS/commit/ef24c526da26a4d3e9c542659e48b32480d0827f>
Python-Pfad:
['/usr/share/qgis/python',
'/home/frank/.local/share/QGIS/QGIS3/profiles/default/python',
'/home/frank/.local/share/QGIS/QGIS3/profiles/default/python/plugins',
'/usr/share/qgis/python/plugins', '/usr/local/lib/python36.zip',
'/usr/local/lib/python3.6', '/usr/local/lib/python3.6/lib-dynload',
'/home/frank/.local/lib/python3.6/site-packages',
'/usr/local/lib/python3.6/site-packages']
How to fix this error? I have no idea where the qgis module is installed
and which search path is the right.
Actual, via update-alternatives --config python I activated python3 in
manual mode
Regards
Frank
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191217/d95efffe/attachment.html>
