[Qgis-user] GDAL Georeferencer Tool Not Appearing In Processing Menu - QGIS 3.4 Ubuntu
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Wed Dec 18 11:29:15 PST 2019
The Georeferencer is a core plugin, which means that it is already
installed, but not activated by default.
You have to open the plugin administration -> "installed" -> checkbox at
GDAL-Georeferencer -> Entry in Raster Menu
This has nothing to do with the processing framework.
If there is still no georeferencer in your raster menu, then there is
something going wrong on your computer. The georeferencer is a stone old
feature which has been there for all times I can remember (and that is 2011)
Am 18.12.19 um 19:08 schrieb Jeff Doty:
> GDAL georeferencer is a plugin, as it is listed in the list of installed plugins. I have seen references to a core QGIS georeference tool under the raster menu, but there is no such tool in my version. Typing georeference in the processing search bar yields no results.
> Get Outlook for Android<https://aka.ms/ghei36>
> ________________________________
> From: Alexander Bruy <alexander.bruy at gmail.com>
> Sent: Wednesday, December 18, 2019, 12:08 PM
> To: Jeff Doty
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] GDAL Georeferencer Tool Not Appearing In Processing Menu - QGIS 3.4 Ubuntu
> Hi Jeff,
> Georeferencer is not a Processing plugin. Look for it in the Raster menu.
> ср, 18 груд. 2019 о 19:00 Jeff Doty <jadoty at hotmail.com> пише:
>> I know this question has been raised several times before, but my situation is somewhat different.  The georeferencer tool does not appear in the processing menu, and I have tried checking the box under the plugin settings - it will stay checked while in same session, but if I close QGIS and restart, the box is unchecked again.  Either way, the tool never appears in the menu.  My installed GDAL version is 2.2.3 which unless I'm mistaken is the correct version for QGIS 3.4.  At any rate that is the version that was included with the installer. Any help would be appreciated.  Jeff Doty
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191218/c5ba8469/attachment-0001.html>
