[Qgis-user] Georeferencer
Richard Duivenvoorde
rdmailings at duif.net
Sun Dec 22 23:15:43 PST 2019
Hi Dave,
can you go over:
https://docs.qgis.org/3.4/en/docs/training_manual/forestry/map_georeferencing.html
and tell us if you hit all those buttons?
Most obvious reasons I can think of based on the info you provide:
- the CRS ("projection") you save your referenced images in is different
then the one of your QGIS project: make sure QGIS knows which crs is
your georeferenced image in (that is: the crs you were georeferencing to)
- the georeferencer plugin saves to geotiff if I'm right, so in a
geotiff the coordatines will be IN the file. For other file formats
there is a 'world file' created [0]. Did you copy both your world file
AND the image?
If you open a new project and ONLY load your referenced image, do you
see appropriate coordinates in the bottom bar of QGIS? If you
georeferenced to lat lon you should see -180 < xy < 180 (epsg:4326 ==
lat lon( etc. If you used google maps you will see epsg:3857 etc etc
Be sure to either georeference using a map in your goal crs, OR use QGIS
later to reproject to your destination crs.
Hope This Helps, Regards,
[0] https://en.wikipedia.org/wiki/World_file
On 23/12/2019 04.07, Dave Gardiner wrote:
> I have been using the QGIS Georeferencer to geo-reference a map image and
> then bring it in to its correct geographic position as a QGIS layer. It's a
> great feature and will save heaps of time instead of having to digitize.
> However, I am not seeing my image appear in the layer (only the dots I used
> as the reference coordinates have come through to the layer and they are in
> their correct position). Can anyone help me with this please?
