[Qgis-user] ModuleNotFoundError: No module named 'txt2tags'
JIA Pei jp4work at gmail.com
Sun Feb 3 05:52:17 PST 2019
Hi, all:
I'm using *Ubuntu 18.04*. And I'm quite sure I've *txt2tags* (an *EXE*)
installed. And I also successfully installed *txt2tags* Python module from
https://github.com/txt2tags/txt2tags . However, I still failed to build
QGIS with the following *ERROR* messages??? Any suggestions?
make[2]: Entering directory '....../QGIS/build'
[  0%] Building ....../QGIS/build/doc/INSTALL from
....../QGIS/doc/INSTALL.t2t
cd ....../QGIS/build/doc && /usr/bin/txt2tags --encoding=utf-8
-o....../QGIS/build/doc/INSTALL -t txt ....../QGIS/doc/INSTALL.t2t
  File "/usr/bin/txt2tags", line 3, in <module>
    import txt2tags
doc/CMakeFiles/t2tdoc.dir/build.make:66: recipe for target 'doc/INSTALL'
failed
make[2]: *** [doc/INSTALL] Error 1
make[2]: Leaving directory '....../QGIS/build'
CMakeFiles/Makefile2:1090: recipe for target
'doc/CMakeFiles/t2tdoc.dir/all' failed
make[1]: *** [doc/CMakeFiles/t2tdoc.dir/all] Error 2
make[1]: Leaving directory '....../QGIS/build'
Makefile:165: recipe for target 'all' failed
make: *** [all] Error 2
Pei JIA, Ph.D.
Email: jp4work at gmail.com
cell in Canada:    +1 778-863-5816
cell in China: +86 186-8244-3503
Welcome to Vision Open
http://www.visionopen.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190203/de267452/attachment.html>
