[Qgis-user] model that runs bat file to obtain vector layer
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Feb 4 13:30:23 PST 2019
I am not a modelling guru but it's my understanding that you can export
the model to python.  My (educated) guess is that you could then modify
this python script to call an external process if it's not already
possible to do it directly in processing.   I see you are looking at
os.system.  That would be my guess also.
https://docs.python.org/3/library/os.html#os.system
Nicolas
On 2019-02-04 3:06 p.m., Reginald wrote:
> Thanks Nicolas,
> You have me some hints on how to do it.
> The bat file was created according to the code of Michel Stuyts.
> I adapted it to work with SSL and I guess I only have to do
> call C:\Osgeo4W64\bin\py3_env.bat # this will make the GDAL SRS database
> available
> os.system([("cmd", "extractwfsdata.bat")])
> My question was in fact if it is posible to run a bat file or a python
> script from within the QGIS modeler tool.
> Any idea?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
