[Qgis-user] [QGIS-Server] WFS-T
    Jonathan Moules
    jonathan-lists at lightpear.com
    Tue Feb  5 04:09:35 PST 2019
Hi Berhnard,
Well, on the issue of why QGIS is using WFS 1.0.0 despite asking for 1.1
- from the docs it appears QGIS Server only supports WFS 1.0.0, so they
"negotiate" down to that version.
I'm afraid I can't help on your other question; hopefully someone else can.
Cheers,
Jonathan
On 2019-02-05 07:54, Bernhard Ströbl wrote:
> Hi Jonathan,
> thank you for looking into this. Basically I want to run a WFS-T
> Server (QGIS-Server), with any client, but to test the server I used
> QGIS desktop.
> In QGIS desktop I specified the version to be 1.1, no idea why the
> transaction request is sent with version 1.0.0
> extract from GetCapabilities:
> <ows:ServiceType>WFS</ows:ServiceType><ows:ServiceTypeVersion>1.1.0</ows:ServiceTypeVersion>
> <ows:Operation name="Transaction">
> <FeatureType>
>   <Name>projekt_pt</Name>
>   <Title>projekt_pt</Title>
>   <DefaultSRS>EPSG:25832</DefaultSRS>
>   <OtherSRS>EPSG:3857</OtherSRS>
>   <Operations>
>     <Operation>Query</Operation>
>     <Operation>Insert</Operation>
>   </Operations>
> So for me the question is: Does the client (QGIS desktop) generally
> work with a QGIS WFS-T Server? If yes why is it not working with my
> QGIS WFS-T Server?
> Bernhard
> Am 04.02.2019 um 18:36 schrieb Jonathan Moules:
>> Hi,
>> Well, taking the error at face value, it seems to be complaining that
>> you have:
>> /REQUEST=Transaction/
>> in the URL. Which is odd because that's exactly what it should be
>> (looking at the 1.0.0 spec).
>> But at the bottom of your error, it says:
>> 10:15:17 WARNING [9148]: Service WFS 1.0.0 not found, returning default
>> So I'd suggest that QGIS Server doesn't support transactions for WFS
>> 1.0.0 (Transactions support is Optional). Except the QGIS docs say
>> they do support Transaction:
>> https://docs.qgis.org/2.8/en/docs/user_manual/working_with_ogc/ogc_server_support.html
>> - and WFS 1.0.0 seems to be the only version supported by QGIS so...
>> are the errors misleading? (I can't seem to readily find that page
>> for QGIS 3.4).
>> The GetCapabilities of the server will tell you if it supports
>> Transaction.
>> Maybe someone who knows QGIS Server (I'm just basing this reply off
>> the spec and your error) can comment.
>> Cheers,
>> Jonathan
>> On 2019-02-01 09:57, Bernhard Ströbl wrote:
>>> Hi all,
>>> I try to make an INSERT to QGIS-Server using WFS-T. But every insert
>>> fails with the server returning "Please check the value of the
>>> REQUEST parameter"
>>> This is the QGIS-server log output (anonymised):
>>> 10:15:17 INFO Server[9148]: ******************** New request
>>> 10:15:17 INFO Server[9148]: SERVER_NAME***
>>> 10:15:17 INFO Server[9148]: REQUEST_URI/wms/pmt?SERVICE=WFS
>>> 10:15:17 INFO Server[9148]: REMOTE_ADDR10.***.***.**
>>> 10:15:17 INFO Server[9148]: CONTENT_TYPEtext/xml
>>> 10:15:17 INFO Server[9148]: HTTP_USER_AGENTMozilla/5.0
>>> QGIS/3.4.3-Madeira
>>> 10:15:17 INFO Server[9148]: MAP:/var/www/wms/karten/pmt.qgs
>>> 10:15:17 INFO Server[9148]: REQUEST:Transaction
>>> 10:15:17 INFO Server[9148]: REQUEST_BODY:<Transaction
>>> xmlns="http://www.opengis.net/wfs" version="1.0.0" service="WFS"
>>> xsi:schemaLocation="http://www.qgis.org/gml
>>> https://pmt-map.jena.de:443/wms/pmt?SERVICE=WFS&REQUEST=DescribeFeatureType&VERSION=1.0.0&TYPENAME=projekt_pt"
>>> xmlns:gml="http://www.opengis.net/gml"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><Insert
>>> xmlns="http://www.opengis.net/wfs"><projekt_pt
>>> xmlns="http://www.qgis.org/gml"><geometry
>>> xmlns="http://www.qgis.org/gml"><gml:Point
>>> srsName="EPSG:25832"><gml:coordinates ts=" "
>>> cs=",">681077.95823665894567966,5643649.18793503474444151</gml:coordinates></gml:Point></geometry></projekt_pt></Insert></Transaction>
>>> 10:15:17 INFO Server[9148]: SCHEMALOCATION:http://www.qgis.org/gml
>>> 10:15:17 INFO Server[9148]: SERVICE:WFS
>>> 10:15:17 INFO Server[9148]: VERSION:1.0.0
>>> 10:15:17 INFO Server[9148]: Request finished in 1 ms
>>> the apache error log says:
>>> QNetworkDiskCache::prepare() unable to open temporary file
>>> any help appreciated
>>> System: QGIS-Server 3.4.4 on Ubuntu/Apache, WFS-Client QGIS Desktop
>>> 3.4.3
>>> Bernhard
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 18802 (20190201) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> signature database 18819 (20190204) __________
>> http://www.eset.com
> signature database 18822 (20190205) __________
> http://www.eset.com
