[Qgis-user] python qgis 3 adding features fails partly
Reginald
Reginald.Carlier at ingelmunster.be
Tue Feb 12 01:16:34 PST 2019
Hello list,
Using the python console in QGIS 3.4.4 with the following code:
<code>
from qgis.PyQt.QtCore import *
from PyQt5.QtGui import *
perceellayer=None
premielayer=None
layers = [layer for layer in QgsProject.instance().mapLayers().values()]
for lyr in layers:
if lyr.name() == "Adpf1836007":
perceellayer = lyr
if lyr.name() == "premies_zwaluwen":
premielayer = lyr
features = perceellayer.selectedFeatures()
geom = None
for f in features:
if geom == None:
geom = f.geometry()
else:
geom = geom.combine(f.geometry())
feat = QgsFeature(premielayer.fields())
feat.setGeometry(geom)
result = iface.openFeatureForm(premielayer, feat, showModal=False)
print(result)
premielayer.addFeature(feat)
premielayer.updateFields()
print("klaar")
</code>
- when premies_zwaluwen is a postgis layer trying to save the edit fails
with the message that id cannot be NULL altough in the featureform I put
another value
- when premies_zwaluwen is a shapefile the geometry gets added but all the
fields of the new feature are empty altough I put a value in every field
from the featureform.
Any idea what I am doing wrong?
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
