[Qgis-user] North arrow in QGIS
Werner Macho werner.macho at gmail.com
Wed Feb 13 00:58:37 PST 2019
Hi Richard,
Thats exactly the thing users can easily learn.
You have to connect the image to a map.
Of course most of the time there will be only one map, but if there are
more the computer does not know which map to connect to (Sync with map)
Once the connection is done (IIRC there is good documentation on this) the
image rotates the same way you rotate the map.
Thats it ..
Once you know how to do it - you'll never forget - and it is handy in a lot
of different ways and helps to know this broad approach.
This is what a search gives me:
https://docs.qgis.org/testing/en/docs/user_manual/print_composer/composer_items/composer_image.html
It's a life long learning isn't it?
regards
Werner
On Wed, Feb 13, 2019 at 9:49 AM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 2/13/19 9:30 AM, Werner Macho wrote:
> > Hi,
> > while I see that a lot of "other" GIS Software has its own button for
> > north arrows I am against adding a north-arrow button.
> > reasons:
> > While this is one of the few points which is not intuitive at a first
> > glance the user has to learn how to add the north arrow (and learn that
> > a north arrow is nothing else than an ordinary image).
> To be honest I'm not so much a user of the Layout-part of QGIS, but
> shouldn't the a North arrow be an essential property of a map, AND
> should the North-arrow not always point to the North of the given crs?
> Trying out here in a layout, if I rotate the map 10 degrees, the arrow
> image is fixed to top. Or do I miss something, like that you can 'fix an
> image to the north' or so?
> Another question that pops up: are all crs's always pointing to 0
> degrees North? And if not is a crs aware of that?
> If so I would opt for either some function to have an intelligent North
> Arrow in layouts (which are aware of crs, so rotate with map), and which
> can reuse the image dialogs?
> Or add such intelligence to the already image props (besides a North
> arrow I can think about images of a ground level which always have to be
> horizontal or so)?
> Sorry for popping up this questions...
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190213/334190e1/attachment.html>
