[Qgis-user] North arrow in QGIS
Andreas Neumann
a.neumann at carto.net
Wed Feb 13 02:12:36 PST 2019
Hi Nyall,
If it is that easy to do (without a lot of duplication (in code and UI))
then I would also be in favor of adding a new separate item for
north-arrows.
It would then just point to the folder that contains the images of
north-arrows and could display the image browser of the available
north-arrows in a non-collapsed state.
Andreas
Am 13.02.19 um 10:17 schrieb Nyall Dawson:
> On Wed, 13 Feb 2019 at 19:01, Bernhard Ströbl <bernhard.stroebl at jena.de> wrote:
>> coming back to the original question: I would not mind to have an
>> additional button for the north arrow, which would be a shortcut to
>> create the image, choose a default north-arrow svg and connect it with
>> the map.
> This is entirely possible without major work -- e.g. the current "add
> arrow" item tool is just a shortcut for drawing lines with an arrow
> head automatically enabled. The end result is the same as if you'd
> drawn a line then turned on the arrowhead.
> We could easily do the same for north arrows, and have the action
> insert a picture, link it to the largest map in the layout by default,
> and default to a NICE north arrow picture.
> Nyall
>> Bernhard
>> __________ Information from ESET Mail Security, version of virus signature database 18866 (20190213) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
