[Qgis-user] change default webbrowser in qgis3 settings?
Groene Bij
mail at groenebij.nl
Mon Feb 25 00:43:50 PST 2019
Hi all,
I am sorry to repeat this question. I really hope someone can help.
Today I did a clean install of 3.4.5 and exporting a map with the plugin
qgis2web it still opens the webmap in IE. I don't use IE, haven't configured
it and it is not my default webbrowser in Win10.
Somehow, some setting in qgis 3 doesn't use my default windows settings
correctly.
Qgis 2.18.28 doesn't have this problem. I also did a clean install of
2.18.28 today, exported a map with the plugin and it opens in my default
webbrowser which is Firefox.
Is it a bug in 3.4.5?
Is there a setting somewhere to change the webbrowser used?
Gr.
Jeroen
Van: Qgis-user <qgis-user-bounces at lists.osgeo.org> Namens Groene Bij
Verzonden: maandag 11 februari 2019 17:10
Aan: qgis-user at lists.osgeo.org
Onderwerp: [Qgis-user] qgis3 uses IE as default browser on windows10?
Is there a setting in qgis3 to change the default internet browser used by
processes?
For instance, qgis2web opens a webbrowser after exporting the webmap. In
qgis2.18 my default browser Firefox was opened. Now, qgis3.4.4 it opens IE.
According to Tom Chadwin (qgis2web) the plugin refers to a piece of Pyhton
code when opening the webbrowser:
The code which opens the browser when you export is:
https://github.com/tomchadwin/qgis2web/blob/master/qgis2web/maindialog.py#L3
42
It uses the Python webbrowser module:
https://docs.python.org/3/library/webbrowser.html
I have no experience with pyhon, so I hope there is a setting somewhere to
choose my default browser. Besides that, I do hope qgis3 will simply follow
the default settings from the OS.
Kind regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190225/c469724a/attachment.html>
An embedded and charset-unspecified text was scrubbed...
Name: Naamloze bijlage 00063.txt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190225/c469724a/attachment.txt>
