[Qgis-user] QGIS 3 Interface Customisation
Luigi Pirelli
luipir at gmail.com
Thu Jan 3 04:21:27 PST 2019
IMHO a good feature request
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Thu, 3 Jan 2019 at 12:41, Paul Wittle <P.Wittle at dorsetcc.gov.uk> wrote:
> Hello,
> I’m trying to create a cut down profile for QGIS 3 to deploy as a viewer
> for low end users. I don’t want to display the settings menu but I do want
> to be able to access it via keyboard shortcuts so I setup keyboard
> shortcuts for “Options” as an example. Unfortunately the keyboard shortcut
> doesn’t appear to work if the settings menu is set to false using the
> interface customisation.
> Is this behaviour what you would expect and if so, would it be worth a
> feature request to change it?
> As I see it you really have three options:
> - Display
> - Hide
> - Hide and disable
> The current versions seems to only have the option to display or disable
> the options but I’m trying to change the menu not disable functionality.
> Best Regards,
> Paul Wittle
> GIS Developer
> Insight, Intelligence & Performance
> County Hall
> Dorchester
> Dorset. DT1 1XJ
> Tel: 01305 228473
> E mail: p.wittle at dorsetcc.gov.uk
> "This e-mail is intended for the named addressee(s) only and may contain
> information about individuals or other sensitive information and should be
> handled accordingly. Unless you are the named addressee (or authorised to
> receive it for the addressee) you may not copy or use it, or disclose it to
> anyone else. If you have received this email in error, kindly disregard the
> content of the message and notify the sender immediately. Please be aware
> that all email may be subject to recording and/or monitoring in accordance
> with relevant legislation."
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190103/499056ff/attachment.html>
