[Qgis-user] Building Qgis Server only
Andreas Neumann a.neumann at carto.net
Mon Jan 7 03:44:18 PST 2019
Hi Henrik,
Here are my cmake parameters (for version 3.4.x):
cmake /build/QGIS -GNinja -DWITH_STAGED_PLUGINS=OFF
-DCMAKE_INSTALL_PREFIX=/usr -DWITH_GRASS=OFF -DWITH_GRASS7=OFF
-DSUPPRESS_QT_WARNINGS=ON -DENABLE_TESTS=OFF -DWITH_QSPATIALITE=OFF
-DWITH_QWTPOLAR=OFF -DWITH_APIDOC=OFF -DWITH_ASTYLE=OFF
-DWITH_DESKTOP=OFF -DWITH_SERVER=ON -DWITH_SERVER_PLUGINS=ON
-DWITH_BINDINGS=ON -DWITH_QTMOBILITY=OFF -DWITH_QUICK=OFF -DWITH_3D=OFF
-DWITH_GUI=OFF -DDISABLE_DEPRECATED=ON -DSERVER_SKIP_ECW=ON
-DWITH_GEOREFERENCER=OFF
Greetings,
Andreas
On 2019-01-07 12:34, Henrik Uggla wrote:
> I'm not able to find how to build Qgis Server without desktop anywhere in the documentation (https://github.com/qgis/QGIS/blob/master/INSTALL). How is it done?
> ________________________________________
> Från: Andreas Neumann <a.neumann at carto.net>
> Skickat: den 7 januari 2019 11:26:30
> Till: Henrik Uggla
> Kopia: qgis-user at lists.osgeo.org
> Ämne: Re: [Qgis-user] Building Qgis Server only
> Hi Henrik,
> You can now build QGIS Server without desktop, but not without X. You still need X for PDF generation (GetPrint command).
> If you are interested, I have docker configurations for QGIS Server 2.x. and 3.x based on Ubuntu and NginX server. Still struggling a bit with NGinX URL forwarding, but hoping to solve it tomorrow with the help of Marco B.
> I could share the configuration, if it helps for you.
> Greetings,
> Andreas
> On 2019-01-07 11:01, Henrik Uggla wrote:
> I would like to create a Qgis Server Docker container based on Alpine. Is it possible to build Qgis Server, without the desktop applications, on a server that doesn't run X?
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190107/b460df89/attachment.html>
