[Qgis-user] After deleting points, attribute rows persist
Patrick Dunford enzedrailmaps at gmail.com
Mon Jan 7 10:18:38 PST 2019
It would in fact, be desirable if the accidental removal of the last
node did not result in a feature being deleted, IMO.
On 8/01/19 4:25 AM, DelazJ wrote:
> Hi Micha,
> The Node Tool is not meant to remove features, but to edit/remove
> their geometries. Your feature persists in your dataset through their
> attributes and you can later use the "Add part" tool to create a new
> geometry.
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#vertex-tool
> For full deletion (data + geometry), you should use the the "Delele
> selected" tool, with a red bin.
> Regards,
> Harrissou
