[Qgis-user] Can not change page setting in Printer Composer (Roberto Herrero)
e
qfasser at gmail.com
Tue Jan 8 04:48:40 PST 2019
Design-->Page setting is for the print
Il 06/01/19 23:02, Roberto Herrero ha scritto:
> I'd been trying to modify the settings in the Design-->Page setting
> menu.
> Following your recommendations I right-clicked on the page and
> everything is OK now. I wonder what the purpose of Desing-->Page
> setting is.
> Thank you very much for your help, Garth.
> Roberto Herrero
> El dom., 6 ene. 2019 a las 22:18, Garth Fletcher (<garth at jacqcad.com
> <mailto:garth at jacqcad.com>>) escribió:
> Roberto Herrero wrote:
> > ... I have changed orientation to portrait and saved the
> > modification. However, I get no effect on the page. ...
> Works OK here under Mac OS X 10.12.6
> In print composer, Ctrl-click on page brings up pop-up menu
> from which I select "Page Properties" to bring up a dialog
> where I can set size & orientation. This seems to be the only
> way to access that dialog - it doesn't appear in the normal
> Item Properties dialog.
> The settings are preserved when the layout is closed and later
> reopened.
> Tested with:
> QGIS version 3.4.3-Madeira
> Compiled against Qt 5.11.2
> Compiled against GDAL/OGR 2.3.2
> Compiled against GEOS 3.7.0-CAPI-1.11.0
> also tested with
> QGIS version 3.4.1-Madeira
> Compiled against Qt 5.11.1
> Cordially,
> Garth Fletcher
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190108/193745dd/attachment.html>
