[Qgis-user] QGIS 3.4.3 becoming unusable for me on Windows 10
Randal Hale
rjhale at northrivergeographic.com
Tue Jan 8 14:35:26 PST 2019
If you started a brand new Profile: Setttings -> User Profile -> New
Profile does it speed up or do the same thing?
My first thought is plugins. This came up a while back but I didn't keep
track of the Email chain.
Randy
On 1/8/19 4:52 PM, Phil Wyatt wrote:
> Hi Folks,
> I am on Win10 64bit, Intel i7 7700 CPU @ 3.60Ghz 16Gb RAM
> Start up time is about 8 seconds with Samsung EVO 500Gb SSD main drive (and multiple 4tb extra drives)
> I think it might be better to tell us something about the individual projects and how they are organised. Shapefiles, networked, size of files, rasters, number of records etc etc?
> Cheers - Phil
> -----Original Message-----
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of David Addy
> Sent: Wednesday, 9 January 2019 5:19 AM
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] QGIS 3.4.3 becoming unusable for me on Windows 10
> Ever since release 3.4.1 QGIS has been a disaster for me, running on Windows
> 10.
> After I upgraded to 3.4.2 I still had problems with everything running very
> slowly. (See my post below -
> QGIS 3.4.2 still very slow to work in Windows 10 by David Addy)
> Now on 3.4.3 the same issues seem to be continuing, with the odd crash added
> in for good measure.
> Opening QGIS on Windows 10 always takes over half a minute before anything
> happens apart from the outline box of the QGIS window full of blank space.
> Once a project finally loads up any random operation gets the "QGIS not
> responding" message.
> I can scan a map without any problem, moving it around works fine, as does
> zooming in and out. But if I want to amend the contents of the attribute
> table or change a style in the Layer Properties I get “QGIS is not
> responding”. After a long delay it may respond correctly.
> This can result in further issues because I may try pressing buttons to get
> a response. After long frustration it might decide to crash.
> I use the stand -alone version of 64 bit Windows package, which loads with
> QT 5.11.2.
> I run a 16 gb computer with Intel i7 processor. It seems to make no
> difference whether I have my Kaspersky Security Suite turned on or off.
> Frustratingly, some other users apparently experience no problems with
> Windows on QGIS.
> Ubuntu users are ecstatic – they work lovely.
> If you are on Windows 10 and are still having these sort of issues on QGIS
> 3.4.3 it would be very helpful if you could add a note to this thread so we
> can gauge the numbers involved. Useful also if you can note whether you use
> the standalone package, 64 or 32 bit, and the QT package installed.
> Thanks very much.
> Sorry to complain, but I just cannot bear to run any work at the moment.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
