[Qgis-user] QGIS does not display raster maps from a GRASS mapset
Veronica Andreo
veroandreo at gmail.com
Thu Jan 10 08:57:49 PST 2019
Hi Pedro and all,
Many thanks for your answers :)
El jue., 10 ene. 2019 a las 16:15, Pedro Venâncio (<
pedrongvenancio at gmail.com>) escribió:
> Hi Veronica,
> This happens also in Windows platforms.
> But if I open the raster layer properties and just do Ok, QGIS assumes a
> default color ramp and the raster shows up (see the attached gif). Can you
> confirm this also in Linux?
Yes, same behaviour in Linux with North Carolina sample data set; if I open
the raster properties and click ok then, the map is displayed, otherwise
invisible.
If I try with raster maps from any other mapset (modis ndvi products or
landsat images), the trick does not work anymore and min and max are always
the same no matter which map i try: Min 1.79769e+308, Max -1.79769e+308
(that's the order, I double checked).
So, it seems that QGIS 3.x is not interpreting GRASS color tables by
> default.
Seems so... nor the statistics of raster maps. And no error reported
anywhere.
For the case of nc_climate location [0], on the other hand, some stats
seems to be recognized, but the map is not displayed following your trick
nor trying to classify and then hitting OK.
In QGIS 2.18.27, raster layers from GRASS Mapsets work without problems.
> I don't know if it is somehow related, but using GRASS algorithms from
> QGIS Processing, when the outputs are rasters, the error message 6 from
> gdal is showed:
> ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in TIFF
> format.
I'll test and let you know
If you confirm this behaviour, please open a ticket at
> https://issues.qgis.org/projects/qgis/issues. Or let me know, and I will
> open it ASAP.
> Thanks to you,
Vero
[0]
http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
Veronica Andreo <veroandreo at gmail.com> escreveu no dia terça, 8/01/2019
> à(s) 14:49:
>> Hi
>> I'm trying to display a raster map I have in a GRASS mapset in QGIS
>> interface and it is not rendered, indeed it is loaded but invisible. It
>> seems QGIS recognizes the color palette from GRASS and all but the raster
>> map is not displayed (vector maps are displayed correctly though). I tried
>> with other raster maps from the same mapset, changing color palette, but
>> nothing happens either, map is not displayed. I use QGIS 3.5 and GRASS GIS
>> 7.4 in a fedora 28 box.
>> Any ideas?
>> Thanks in advance,
>> Vero
>> ps: See a screenshot here:
>> https://drive.google.com/open?id=1oGfVl-poy2tWL7Em6RwXu2TRkwAWMtW5
>> (otherwise my post does not go through)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190110/a4a303d2/attachment-0001.html>
