[Qgis-user] Diameter of buffers
Jorge Gustavo Rocha
jgr at geomaster.pt
Mon Jan 14 06:39:42 PST 2019
Hi Herbert,
You are using a Mercator based projection to calculate distances [1]. It
was not designed for distance calculations.
Can you reproject to your own national/local projected coordinate
system? Compute the buffers using it and compare the results.
Regards,
Jorge
[1] https://en.wikipedia.org/wiki/Mercator_projection
Às 14:21 de 14/01/19, Herbert Faber escreveu:
> Dear all,
> When I put ring buffers arond dot objects, the diameter doesn't
> come out as I would expect.
> For instance, when I try to make ring buffer with a distance of 100
> meter and 25 segments around a dot object. The diameter of the buffer
> turns out to be approx 126 m when I measure it with the ruler tool.
> What am I doing wrong?
> I work with OSM Standard map in EPSG:3857 - WGS 84 / Pseudo-Mercator
> - projection and so are my shape files.
> Best regards,
> Herbert Faber
> Qgis-user mailing list
Logo* Geomaster, LDA*
*VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC**O
Avenida Barros e Soares
N.º 423, 4715-214 Braga
VAT/NIF510 906 109
Phone +351 253 680 323
Site geomaster.pt <http://geomaster.pt>
GPS 41.53322, -8.41929
Jorge Gustavo Rocha
CTO
Mobile +351 910 333 888
Email jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190114/879c769b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190114/879c769b/attachment-0001.png>
