[Qgis-user] Impossibilità connessione repository Qgis 3.4 e WMS
Alexandre Neto
senhor.neto at gmail.com
Sun Jan 20 07:19:36 PST 2019
You seem to have problems with two very different things, but both need an
internet connection. Maybe you need to set a proxy.
You can set it in QGIS under settings > options > network.
https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html?highlight=proxy#network-settings
Alexandre Neto
A dom, 20/01/2019, 14:40, Richard Duivenvoorde <rdmailings at duif.net>
escreveu:
> Hi Giuseppe,
> Your repo url is just fine, QGIS will add the version behind it and that
> one works:
> https://plugins.qgis.org/plugins/plugins.xml?qgis=3.4
> Maybe a connection issue on your side, or a server hickup on ours?
> Please try again.
> Your WMS url works fine with me too, opening it in a web browser gives
> an arcgis error, but if you create a WMS connection with it I can load
> the layer:
> Volo_ATA_1997
> in epsg:3004 which looks like this: http://duif.net/temp/italy.png
> Are you sure your connection is ok?
> Regards,
> On 1/20/19 3:13 PM, Giuseppe Guarino wrote:
> > I apologize. I have a problem with the Qgis repository/wms connection
> > that I tried to resolve asking on the Facebook page Qgis Italia
> https://www.facebook.com/photo.php?fbid=10215898601011242&set=gm.10157066011701385&type=3&eid=ARBBRUY5JeRY6w35Dw3dC1A0Ko0l4ovq8g5ZTqxRtR8NOnFFPlZDQSJ2qdTxaNydMFyqWm0dKQiUrNbA&ifg=1
> > But I still could not solve it.
> > This is the url of repository I use:
> > and also with the WMS connection. This is the
> > url:
> http://map.sitr.regione.sicilia.it/arcgis/services/Grafici_Volo_ATA_1997/MapServer/WMSServer
> > Regards,
> > Giuseppe Guarino
> > ᐧ
> > Il giorno dom 20 gen 2019 alle ore 12:48 Richard Duivenvoorde
> > <rdmailings at duif.net <mailto:rdmailings at duif.net>> ha scritto:
> > On 1/20/19 12:42 PM, Giuseppe Guarino wrote:
> > > Ciao a tutti,
> > > tempo fa avevo aperto un post sulla pagina Facebook "GIS ITALIA"
> > > sull'impossibilità, da parte del mio Qgis 3.4, di connettersi sia
> al
> > > repository sia ai link per scaricare dati wms/wfs. Attualmente ho
> > anche
> > > installata la versione di Qgis 2.8, dove però funziona tutto bene.
> > > Grazie all'aiuto di Stefano Campus siamo riusciti a capire che è un
> > > problema legato alla rete, poiché da terminale utilizzando il
> comando
> > > ping + l'URL del repository non riusciva a connettersi dando come
> > > errore "impossibile trovare l'host".
> > > Qualcuno ha avuto lo stesso problema ed è riuscito a risolverlo?
> > Hi Giuseppe,
> > not exactly sure what you ask, as most of us here do not speak
> > italian :-)
> > But please provide an url so we can test/check
> > Regards,
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190120/76bbe3bb/attachment.html>
