[Qgis-user] Project files with local and remote connections to postgreSQL databases
Laurence Béchet
bechet.laurence at gmail.com
Thu Jan 24 16:31:11 PST 2019
Thanks for the answers. Sorry have not checked Brent's suggestion as the
pg_services just work beautifully.
Maybe I have not been looking carefully, but it would be nice if it were
a bit more documented in qgis doc - at least mentioned with an example ;o)
Kind regards
Laurence
Ark in the Park volunteer co-ordinator
On 11/01/2019 8:00 PM, Paolo Cavallini wrote:
> Use pg_services.
> Il 11 gennaio 2019 01:54:24 CET, Brent Wood <Brent.Wood at niwa.co.nz> ha
> scritto:
> This is not tested, but I think it should work
> Enable host based access for local connections via the server IP
> address in your pg_hba file and use this for all QGIS access, so
> you apply the same access approach for both local & remote
> connections.
> Cheers
> Brent Wood
> Programme leader: Environmental Information Delivery
> NIWA
> DDI: +64 (4) 3860529
> <http://www.niwa.co.nz>
> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> T +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade, Greta Point, Wellington
> Connect with NIWA: niwa.co.nz <https://www.niwa.co.nz>Facebook
> <https://www.facebook.com/nzniwa>Twitter
> <https://twitter.com/niwa_nz>LinkedIn
> <https://www.linkedin.com/company/niwa>Instagram
> <https://www.instagram.com/niwa_science>
> To ensure compliance with legal requirements and to maintain cyber
> security standards, NIWA's IT systems are subject to ongoing
> monitoring, activity logging and auditing. This monitoring and
> auditing service may be provided by third parties. Such third
> parties can access information transmitted to, processed by and
> stored on NIWA's IT systems.
> ________________________________________
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of
> Laurence Béchet <bechet.laurence at gmail.com>
> Sent: Friday, January 11, 2019 13:04
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Project files with local and remote
> Hi,
> I am having a basic problem with my project files. I usually run qgis
> locally, where the PostgreSQL database is. However, sometimes I
> need to
> have these same projects run on a remote computer (where a version a
> qGIS is locally installed, but the connection to the database is
> remote). And then the project file 'doesn't work' because the expected
> connection to the database is locally not remotely, and I have not
> figured out how to modify this parameter when the project is loaded in
> qGIS. My current work around is to create a specific project for the
> remote computer.
> However this solution is annoying when you have plenty of
> composers that
> you lose in the process ... and playing directly in the xml
> project file
> is a bit scary ...
> Anybody would have an idea how to fix the problem?
> Kind regards
> Laurence Béchet
> ARK IN THE PARK Volunteer Co-Ordinator
> Cascades Ranger Station
> Falls Road, Waitakere
> Phone: (09) 810 7014
> www.arkinthepark.org.nz www.forestandbird.org.nz
> Qgis-user mailing list
> Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190125/95aaeb6f/attachment.html>
