[Qgis-user] Problems QGIS 3.4 - Size fount and export to PDF - Help
Nyall Dawson
nyall.dawson at gmail.com
Mon Jan 28 15:53:25 PST 2019
On Sun, 27 Jan 2019 at 12:42, Wilmer Orlando Martinez Bojaca
<womartinezb at unal.edu.co> wrote:
> Hi!
> Well, with which resolution you export the layout?
> In my case when I change the fount on the project window, the change immediately can see it on the layout window, but when I try change the fount in the legend on the layout window, anything change. I try too restart the software but happen the same thing, the fount doesn´t change.
> I have Mojave Mac 64x.
Which OSX installer are you using?
Nyall
> On Sat, Jan 26, 2019 at 9:33 PM Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
>> Windows 10 64, fresh QGIS install with OSGeo4w64 with latest version (not nightly build)
>> Nicolas
>> > Le 26 janv. 2019 à 21:31, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>> > On Sun, 27 Jan 2019 at 12:16, Nicolas Cadieux
>> >> Hi,
>> >> I just noticed today that changing the font type and size does not change in the layout window even after a refresh. I do see it if I export it as a PDF. Looks like a bug...
>> > Are you on OSX?
>> > Nyall
>> >> Nicolas
>> >> Le 26 janv. 2019 à 19:16, Wilmer Orlando Martinez Bojaca <womartinezb at unal.edu.co> a écrit :
>> >> Hi everyone!
>> >> I have two problems with my QGIS, it looks so simple
>> >> 1. When I try to change the fount size in the legend, the program doesn't works. Thats mean, I can change the size (i.e. 12 to 10) but when I accept (press ok) the size is the same. I'm tried many times but never change anything.
>> >> 2. When I try to export the project to PDF, the final document appear empty (is a blank sheet) without any information, absolutely nothing. In this step I always select print like raster with 3000 ppp like export resolution.
>> >> I have QGIS 3.4 on Mac.
>> >> Anybody could help me please? Maybe is a simple set up.
>> >> Gracias. Saludos,
>> >> Orlando Martínez Bojacá
>> >> Profesional Especializado - Proyectos Productivos - FENSUAGRO
>> >> Zootecnista - Universidad Nacional de Colombia
>> >> Candidato MSc en Geomática - Universidad Nacional de Colombia
>> >> Tel. +57 3505731220
>> >> Skype. womartinezb
>> >> Linkedin. Orlando Martínez Bojacá
>> >> Antes de imprimir este correo piense bien si es necesario hacerlo. ¡El medio ambiente es cosa de todos!
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
