[Qgis-user] Not valid data source on wms layer access for QGIS 3.8
Andrea Peri
aperi2007 at gmail.com
Sat Jul 6 06:11:44 PDT 2019
Hi, Richard,
I like to reproduce what you are reporting me:
>- started with QGIS Master and the normal WMS dialog: I saw 10 layers
><and could load the aerials
The layers are surelly 8 not 10.
But meanwhile 6 layers are from rasters source (they could not have any
rendering). There is also one layer from a vector source (the layer named:
rt_ofc.5k16.32bit.qu) and it have two distinct and choosable style.
So I guess you are seeing the two styles definition and treat it as two
distinct layers . They instead are only two styles of a layer. Also one of
them is the default style.
The two styles are:
"contorno_blu_fine_senza_etichetta"
and
"contorno_blu_fine_con_etichetta"
so choosing the vector layer (the queriable layer) leaving the style
parameter empty it return the default.
So I guess this explain the your report of 10 layers. 8 layers + 2 styles.
But also you report:
>same session, I opened that node on the browser and then saw MUCH more
>layers (a lot of vector layers 'added') and could all load them
I like to understand better what is this.
But I don't understand what you mean with "opened that node on the browser"
. You mean a special browser inside QGIS ?
Many thx for help.
A.
Il giorno ven 5 lug 2019 alle ore 10:04 Richard Duivenvoorde <
rdmailings at duif.net> ha scritto:
> On 05/07/2019 08.18, Alessandro Pasotti wrote:
> > On Fri, Jul 5, 2019 at 8:13 AM Andrea Peri <aperi2007 at gmail.com
> http://www502.regione.toscana.it/ows_ofc/com.rt.wms.RTmap/wms?map=owsofc
> > When I try to add it to a map canvas the connection return le list
> > of layer .
> > Choosing one and using the EPSG:3003.
> > When Add to the canvas I see an error NOT VALID DATA SOURCE.
> > The same steps instead work correctly with the old QGIS 2.18.
> > Is this confirmed from some other one ?
> I'd say there is something wrong with the server (different endpoints?
> url rewriting? proxies?). Because depending on the time and version I
> get different results all the time:
> - same session, I opened that node on the browser and then saw MUCH more
> - started 3.8 and saw the layers but could not load them
> - started master again and saw both in dialog and in browser only the 10
> layers
> - now I keep seeing only the 10 ortho's (and can load them both in
> Master and 3.8.0 which I have here.)
> This is the url QGIS fires:
> http://www502.regione.toscana.it/ows_ofc/com.rt.wms.RTmap/wms?map=owsofc&SERVICE=WMS&REQUEST=GetCapabilities
> as curl command
> curl
> -H 'User-Agent: Mozilla/5.0 QGIS/3.9.0-Master' --compressed
> My guess is there is something with the service...
> Can you maybe sent me a saved project with a layer that does not load
> with you?
> Can you try to install the QGIS Network logger plugin to see and check
> the url's (and replay the urls in the browser)
> Regards,
> Richard
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190706/569e244b/attachment.html>
