[Qgis-user] Postgis layer: attributes not editable if field has a default value
tommaso tommasodb at googlemail.com
Thu Jul 11 05:09:18 PDT 2019
Hello,
I'm using Qgis 3.4.4 Madeira on Ubuntu 16.04 and it seems that the
attributes of Postgis layers are not editable if the corresponding field
has a default value at the database level.
I observed this issue with fields of type boolean and hstore.
For example, if the field "active" of the table "test" has a default value:
Table "test"
Column | Type | Modifiers
  id    | integer |
  name  | hstore  |
active | boolean | default true
than the field "active" is not editable in the attribute table in Qgis.
Could you please help me?
Regards Tom
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190711/6d0a6222/attachment.html>
