[Qgis-user] Problemi con Windows 10?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Jul 15 17:24:58 PDT 2019
If your network drive stops spinning because it’s on a timer, it could take about that time to spin them up.  Try disabling the power saving modes in the NAS.
An easy test is to modify the file.  The first Time it could take a long time.  Then save the modifications and try again rapidly.  If the second accès to the file is fast, then your NAS is stopping the HD from spinning to save energy. If not, it’s another problem.
Nicolas
> Le 15 juill. 2019 à 16:29, Bernd Vogelgesang <bernd.vogelgesang at gmx.de> a écrit :
> Translated by deepl.com ;)
> Good morning to all, I write this email to expose a problem that I find from 3 - 4 months to this part. I say that I use QGIS locally but my PC is part of a small network and the project files are saved on a NAS. The version of QGIS that I use is the most recent operating system is Windows 10.
> The problem is the following: very (too) long waiting time (20 seconds, sometimes even more) to access the properties of the layer and also to change the properties themselves, if I repeat the click at the top left next to the project name appears the message QGIS does not respond.
> Does anyone have any idea what the cause of the problem may be? Could it be my network or operating system or an incompatibility of QGIS with Windows 10?
> Thank you.
> Translated with www.DeepL.com/Translator
>> Am 15.07.19 um 19:05 schrieb Roberta:
>> Buongiorno a tutti, scrivo questa mail per esporre un problema che riscontro da 3 – 4 mesi a questa parte. Premetto che uso QGIS in locale ma il mio PC fa parte di una piccola rete ed i file di progetto vengono salvati su di un NAS. La versione di QGIS che utilizzo è la più recente il sistema operativo è Windows 10.
>> Il problema è il seguente: tempo di attesa molto (troppo) lungo (20 secondi, talvolta anche di più) per accedere alle proprietà del layer ed anche per la modifica delle proprietà stesse, se ripeto il clic in alto a sinistra accanto al nome del progetto compare il messaggio QGIS non risponde.
>> Qualcuno ha idea di quale può essere la causa del problema? Potrebbe essere la mia rete o il sistema operativo o un’incompatibilità di QGIS con Windows 10?
>> Grazie.
>> Roberta  Benetti
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190715/2c39e0cd/attachment.html>
