[Qgis-user] automating the updating of records in existing layer using values from a joined layer
Janneke van Dijk
janneke.qgis at gmail.com
Mon Jul 22 23:44:53 PDT 2019
Dear all,
I will be getting data from the field (geopackage files) on a regular
basis and need to join them to the 'masterfile' and update a few column
values based on the joined attribute values. This works fine manually,
either by using the field calculator or the update bar with the table in
editing mode. I would like to automate parts of this process and am
getting stuck in different attempts.
1. In the model builder, I cannot figure out how to make the field
calculator take only the selected records to be updated, and I cannot
figure out how to make it update records in the existing layer as
opposed to creating a new layer. Is this even possible?
2. In DB manager, I can select the joined masterfile (with fieldwork
file) as a virtual layer (selects 174 rows, including the joined attributes)
select * from masterfile
where fld_date_updated > '2019-07-19'
but I get a syntax error in the update statement:
update masterfile set result_account = fld_result_account where
"Query execution error on CREATE TEMP VIEW _tview AS update masterfile
set result_account = fld_result_account where fld_date_updated >
'2019-07-19': 1 - near "update": syntax error"
I can not find the syntax error. Is this because it's a virtual layer
and it cannot be updated? Is there a way to update records in virtual
layers?
3. In DB manager, if I make a connection under geopackage with the
master file, I am not able to make a join with the virtual layer with
the field data, it will not recognise the field layer.
I am a bit baffled, as I would think this should be something
straightforward. Is what I want possible, using either the model builder
or the db manager and a reusable sql script? Or is it not possible to
semi-automatically update records from within QGIS without having to
create a new output file?
Using QGIS 3.8.1 (osgeo installer) 64 bit on windows 10
Thanks for any insights,
Janneke
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190723/7e7fbd35/attachment.html>
