[Qgis-user] Problem with the raster combine tool (in spanish combinar) (ruben dp)
Mike Flannigan mikeflan at att.net
Wed Jul 24 05:13:06 PDT 2019
Try installing GDAL
https://gdal.org/
and see if gdal_merge.py gets installed in /bin/sh.
This isn't likely to fix your problem, but it won't
hurt either.  If you read the GDAL documentation
you might find that you can do the combine in GDAL.
Mike
On 7/23/2019 3:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Date: Tue, 23 Jul 2019 12:56:58 +0200
> From: ruben dp<rubendeprado at gmail.com>
> To:qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Problem with the raster combine tool (in
> Message-ID:
> 	<CAJ_nwW6ZNtg+Vq0Aj+7+_Lk9YHxWCsO_SEZ_pdXwmRSN7URdxg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello Jorge, thank you very much for answering me.
> I have done what you said me but now, I get a message that says:
> "Procesando algoritmo...
> Algoritmo 'Combinar' comenzando…
> Input parameters:
> { 'DATA_TYPE' : 5, 'INPUT' :
> ['/Users/rubendp/Desktop/mapabardenasreales/mag244/mag244.jpg','/Users/rubendp/Desktop/mapabardenasreales/mag245/mag245.jpg','/Users/rubendp/Desktop/mapabardenasreales/mag282/mag282.jpg','/Users/rubendp/Desktop/mapabardenasreales/mag283/mag283.jpg'],
> 'NODATA_INPUT' : None, 'NODATA_OUTPUT' : 0, 'OPTIONS' : '', 'OUTPUT' :
> '/Users/rubendp/Desktop/mapabardenasreales/litoconj.tif', 'PCT' : False,
> 'SEPARATE' : False }
> GDAL command:
> gdal_merge.py -a_nodata 0 -ot Float32 -of GTiff -o
> /Users/rubendp/Desktop/mapabardenasreales/litoconj.tif --optfile
> /var/folders/6d/nwh8s8sn2cn2rlqb0hkj2_h40000gn/T/processing_9aed1cfafdfd4562b899e3204e709eed/c532e757389249e3af6813197065c542/mergeInputFiles.txt
> GDAL command output:
> /bin/sh: gdal_merge.py: command not found
> Execution completed in 0.07 seconds
> Results:
> {'OUTPUT': '/Users/rubendp/Desktop/mapabardenasreales/litoconj.tif'}
> Cargando las capas resultantes
> Las siguientes capas no se generaron
> correctamente.<ul><li>/Users/rubendp/Desktop/mapabardenasreales/litoconj.tif</li></ul>Puede
> comprobar el «Panel de mensajes del registro» en la ventana principal de
> QGIS para encontrar más información sobre la ejecución del algoritmo."
> In the Log Message Panel (in spanish "Panel de mensajes del resgistro") I
> 2019-07-23T12:48:46     INFO    gdal_merge.py -a_nodata 0 -ot Float32 -of
> GTiff -o /Users/rubendp/Desktop/mapabardenasreales/litoconj.tif --optfile
> 2019-07-23T12:48:46     INFO    GDAL execution console output
> Thanks in advance,
> Ruben.
