[Qgis-user] openning qgis in google drive
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Jul 29 06:19:04 PDT 2019
I had a similar problems with a python IDE, (Eclipse).   I think it has to do with the software, in this case QGIS, locking files when been used so that other users can not modify them while the file is used by another user.  Unless you use a database, most file type are not made for multiuser environments.   While the file is locked, google cannot update it.  If you close QGIS, Google Drive will have access to the files and should then update the results elsewhere.
Nicolas
> Le 29 juill. 2019 à 07:19, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi
> I wish to be able to open my files in google drive in my laptop
> somehow it doesn't work
> he drive don't direct it to the  qgis program not in the laptop and not in any pc
> is it possible?
> thanks
> boaz
> Qgis-user mailing list
