[Qgis-user] create clean knot-edge-model
Christoph Jung
jagodki.cj at gmail.com
Mon Jul 29 10:55:20 PDT 2019
Thank you, Nicolas. I will have a look on all.
Sincerely,
Christoph
> Am 27.07.2019 um 17:02 schrieb Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Btw Christoph,
> If you have multiple shortest path routes to figure out (as in hundreds, millions, or billions in my case), contact me. I am working on a python script to do that.
> Nicolas
>> Le 27 juill. 2019 à 10:56, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> a écrit :
>> Hi,
>> You have multiple plugins and tools available. You can download the following plugins:
>> Geometry Checker
>> Topology Checker
>> Look in the main menu or in the processing tool box for the following:
>> Multipart to Singlepart
>> Check validity (use both methods)
>> Remove duplicate vertices
>> Deleted duplicate geometries
>> Snap geometries to layer, (search for snap in processing)
>> V.clean (break an snap,rmdangles....) see the cleaning tools.
>> Some of these are unstable like check Geometries. Try fixing one problem at a time for better stability.
>> Nicolas
>>> Le 27 juill. 2019 à 06:31, Christoph Jung <jagodki.cj at gmail.com> a écrit :
>>> Hello at all,
>>> does anybody know, if QGIS has a function to create a clean knot-edge-model from an unclean road network? PostGIS provides the function createTopology to achieve it, has QGIS an equivalent function?
>>> Sincerely,
>>> Christoph
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
