[Qgis-user] Forms, realtions and foreign keys
Matthias Kuhn matthias at opengis.ch
Tue Jun 4 02:27:13 PDT 2019
Hello,
If you enable "evaluate default values server side" and "automatic
transaction groups" and set the foreign key check in the database to
initially deferred you'll get pretty much what you want :)
Hope that helps
Matthias
On 6/4/19 11:14 AM, Karl Magnus Jönsson wrote:
> Hi list!
> I have a project with tree tabels stored in PostGIS. One is holding
> the geometry the other two is holding data related to the first table
> as child and grandchild. I have set up foreign keys between the tables
> in the database to be sure that there will be no orphan records. In
> QGIS there are relations and (sub)forms. When I digitize a new
> geometry I get the new id from the database (before it’s saved, OK) in
> the form but I can’t add any children. I get a database error that
> says that there are no parent with that ID (and that’s true). I have
> to  press OK to create the feature in QGIS, change tool to identify,
> find the feature and klick on it to open the form again. Then I can
> add children. But I haven’t saved so there is still no parent. But it
> works then. It’s the same with the grandchild table but then the
> grandparent form is still open so it’s not such a big problem. Anyone
> got a better way to skip this closing and reopening of the form in the
> workflow?
> *Karl-Magnus Jönsson*| Gis-Utvecklare
> Geografisk information
> Miljö- och samhällsbyggnadsförvaltningen
> Kristianstads kommun
> Besöksadress: Västra Storgatan 12
> Postadress: 291 80 KRISTIANSTAD
> Telefon: 044-135416 | Mobil: 0733-135416
> E-post: Karl-Magnus.Jonsson at kristianstad.se
> <mailto:Karl-Magnus.Jonsson at kristianstad.se>
> www.kristianstad.se <http://www.kristianstad.se/>
> Läs mer om hur vi hanterar dina personuppgifter på
> www.kristianstad.se/personuppgifter
> <http://www.kristianstad.se/personuppgifter>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190604/2ef11373/attachment.html>
