[Qgis-user] exporting layout to pdf changes output of locked maps
Harrissou
delazj at gmail.com
Tue Jun 4 02:33:37 PDT 2019
That should have worked without map themes, too.
1- Set the main map canvas to aerial photo, refresh the print layout (should be optional), lock one of the map items
2- Set the main map canvas to topo maps now, refresh the print layout (again should be optional but will show whether the locking works), lock the second map item.
3- Export
If that doesn't work, then there might be an issue worth reporting.
Regards,
Harrissou
Le 4 juin 2019 11:02:41 GMT+02:00, Reginald <Reginald.Carlier at ingelmunster.be> a écrit :
>Hi,
>Using a different map theme works!
>Good to know.
>I'm still a little bit puzzled why the locking didn't work.
>Regards,
>Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190604/fa4ae921/attachment.html>
