[Qgis-user] Points along geometry
Raymond Nijssen r.nijssen at terglobo.nl
Tue Jun 11 12:49:51 PDT 2019
Hi Elisenda,
I'm afraid you need a bit of python script to do so, since the algorithm
dialog does not have an expression input button for the distance field.
Should go something like this:
inputLayer = iface.activeLayer()
for feat in inputLayer.getFeatures():
     dist = feat['DIST'] # field name with distances
     geom = feat.geometry()
     l = 0
     while l < geom.length():
        p = geom.interpolate(l)
        print(p)
        l += dist
Hope this helps,
Raymond
On 11-06-19 12:15, elisenda montaner wrote:
> Hi all,
> I'm trying to create points along lines using the tool 'points along
> geometry'.
> I would like to use different distances for each line at start/end point
> which I have a column with this data in the attributes.
>   Is this possible with this tool? I've tried it and it doesn't seem to
> work.
> Any help would be appreciated. Thanks
> Elisenda
> Qgis-user mailing list
