[Qgis-user] Generate autofield
Germán Carrillo carrillo.german at gmail.com
Wed Jun 12 04:36:59 PDT 2019
Hi Jose,
it was possible in QGIS v2.x with the plugin AutoFields [1]. Now in QGIS
3.x some devs have partially implemented the AutoFields functionalities
into QGIS core, but your use case is still not supported.
However, a project in Colombia [2] is funding exactly that use case. It
could land into QGIS soon. I'll come back to this thread when it happens.
Regards,
Germán
[1] https://github.com/gacarrillor/autofields
[2] https://www.proadmintierra.info/
El mié., 12 jun. 2019 a las 4:09, Andreas Neumann (<a.neumann at carto.net>)
escribió:
> Hi José,
> QGIS has the concept of a virtual field - see
> https://docs.qgis.org/3.4/en/docs/user_manual/working_with_vector/attribute_table.html#creating-a-virtual-field
> Greetings,
> Andreas
> On 2019-06-12 11:06, Jose C. Rodríguez Durán wrote:
> Hi everybody,
> I'm trying to generate an automatic field, I mean, a field that depends
> for two others. We have FIELD1, FIELD2 and SUM. The result should be SUM =
> FIELD1 + FIELD2. The thing is, if I change the value of FIELD1, the value
> of SUM should change. Example: FIELD1 (8) + FIELD2 (10) = SUM (18)  ----->
> FIELD1 (4) + FIELD2 (10) = SUM (14)
> Any idea??
> Thanks in advance for your help!!
> *José C. Rodríguez Durán*
> Qgis-user mailing list
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190612/d356833c/attachment.html>
