[Qgis-user] Opening attribute table for large datasets
Saulteau Don sault.don at gmail.com
Wed Jun 12 20:13:19 PDT 2019
Hi William, fellow BC'er here.
One thing you can do is change the default behaviour, like instead of
loading all features, try loading only features visible on map (or selected
features).
Can change that in Settings > Options then the Data Source tab. You'll see
an "attribute table behavior" pull down menu with some self-explanatory
options.
Some hotkeys that also work, without changing the default attribute table
behaviour are:
F6 - open attribute table
Shift + F6 - open attribute table showing only selected features
CTRL + F6 - open attribute table showing only visible features on canvas
Happy QGIS'ing!
On Wed, Jun 12, 2019 at 6:50 PM Patrick Dunford <enzedrailmaps at gmail.com>
wrote:
> Is the attribute table failing to load or simply taking a very long time
> to load?
> I use some old shapefiles with around 500,000 rows, they are very slow
> loading, it just takes a time, I think is probably the same for a lot of
> large datasets, but it doesn't have trouble drawing the layers on the canvas
> On 13/06/19 11:28 AM, Burt, William FLNR:EX wrote:
> Hi users.
> I am looking for some best practice tips for working with datasets with
> many rows.  Using QGIS 3.4.4 Our organization regularly works with large
> oracle database tables covering a large geographic region(eg 2 M+ rows, 1 +
> Gb).  QGIS seems to draw these layers fine but chokes on them when opening
> the attribute table.  Is there a way to limit fetched rows or other best
> practices in cases like this?
> Thanks for your time,
> Will
> Qgis-user mailing listQgis-user at lists.osgeo.org
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190612/762d2ea0/attachment.html>
