[Qgis-user] proj 4 use degrees instead of grad
Julien Guilloux
julien.guilloux at ecrins-parcnational.fr
Fri Jun 14 04:04:09 PDT 2019
Hi list,
I would like to generate a polygon grid. The coordinate system i need is the old French NTF (with grad unit and Paris as first meridian).
No trouble, there is the espsg code: 4807. When looking description of 4807 in spatialrefsys, grad as unit are well indicate. So... all seem perfect.... but...
When i generate the shape grid, i notice that proj 4 consider the unit as degrees and not as grad !
That why the location of my generate shape is not good, with a difference exactly egal to a 0.9 factor (a circle in grad is 400g, a circle in degrees is 360°, so 1 grad = 0.9 degree)
Do proj 4 understand only degree coordinates ?
i try to make a personnal SRID but no success...
Thanks if you have any tip...
So long,
Julien
Julien-Pierre GUILLOUX
Parc national des Écrins
04 92 40 20 56 / 06 99 77 38 26
[ http://www.ecrins-parcnational.fr/ | www.ecrins-parcnational.fr ]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190614/c8e0da18/attachment.html>
