[Qgis-user] encoding csv to windows-1252 does not work
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Tue Jun 18 04:34:56 PDT 2019
Hi there,
> The text files are in Windows 1252 encoding. When importing them I
> chose this encoding but as you can see from the screenshot it shows
> an encoding of utf-8.
Which version of QGIS are you using? With stable and master QGIS3,
I cannot reproduce it with the file attached. Be aware that it gets
UTF-8 once imported to QGIS. So it'll be UTF-8 in the table, too.
[local] tobwen at qgis=# select * from public.french
│ id │ quote │
│ 1 │ Lhabit ne fait pas le moine │
│ 2 │ Chacun voit midi à sa porte │
│ 3 │ Mieux vaut prévenir que guérir │
Best regards,
Tobias
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190618/e52cff10/attachment.obj>
