[Qgis-user] linking/joining tables
Richard McDonnell richard.mcdonnell at opw.ie
Thu Jun 20 07:01:48 PDT 2019
Why not carry out the join using the Layer Properties, It will allow you to join based on a common column.
This can be found under Joins in Layer Properties, hit the Plus sign and select your Join Layer, your Join Field and then select your Target Field
Be aware that this doesn’t modify either layer, you will have to save it out as another vector file to make the added fields permanent. Hope that helps!
Regards,
Richard.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Pat Brown
Sent: 20 June 2019 14:18
To: QGIS Mailing List <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] linking/joining tables
I have a layer which displays quarter degree squares for the whole country. I also have a csv file containing two fields. One of these is a field for quarter degree squares and the other is a plant that occur in those QDSs. The same plant species occurs in a number of different QDSs. I want to join the tables so that I can display the QDSs that have an occurrence of that plant species. I have tried using MMQGIS, using the common filed in each table. However I get an error message:
AttributeError: 'QVariant' object has no attribute 'lower'
  File "C:/Users/Pat/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\mmqgis\mmqgis_dialogs.py", line 648, in run
    output_file_name, self.mmqgis_status_callback)
  File "C:/Users/Pat/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\mmqgis\mmqgis_library.py", line 678, in mmqgis_attribute_join
    key = attributes[join_index].lower().strip()
I am obviously doing something wrong. Can someone please point me in the right direction to sort this out?
Thanks,
Paddy
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190620/b2c38f9b/attachment.html>
