[Qgis-user] Table manager
Etienne Trimaille etienne.trimaille at gmail.com
Tue Jun 25 01:08:51 PDT 2019
Indeed Table Manager was already deprecated for some functions in QGIS 2
IIRC.
But it depends what you wanted to do with TableManager. If you simply
wanted to rename fields, you can go in the vector layer properties,
"fields" tab and rename columns there. No need to use the "refactor fields"
algorithms, which will regenerate a new layer.
Le sam. 22 juin 2019 à 22:36, carlos h <carloslda256 at gmail.com> a écrit :
> Thank you!
> AC
> El sáb., 22 jun. 2019 a las 14:11, Bernd Vogelgesang (<
> bernd.vogelgesang at gmx.de>) escribió:
>> Hello!! the plugin table manager did not locate it in QGIS 3.4, has it
>> been removed?
>> Thank you
>> CA
>> Afaik, the Table Manager is dead since 3.0, and people are encouraged to
>> use the "Refactor fields" function in the Processing Toolbox.
>> Cheers,
>> Bernd
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190625/e9ec9449/attachment.html>
