[Qgis-user] QGIS Server qgis-auth.db
Alessandro Pasotti apasotti at gmail.com
Tue Jun 25 07:24:01 PDT 2019
On Tue, Jun 25, 2019 at 4:17 PM Overkamp, Stefan <overkamp at rvr.ruhr> wrote:
> Hi,
> I’m trying to configure Authentication Configuration for QGIS Server 3.4.9
> In Apache2 I have set environment variables:
> FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH /mypath/withoutqgisauthdb/
> FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE /mypath/withoutqgis-auth.db/
> Then I Have these files
> /mypath/withoutqgisauthdb/qgis-auth.db and
> /mypath/withoutqgisauthdb/authpwd with masterpassword
QGIS_AUTH_PASSWORD_FILE needs to point to a full path to the text file
containing the password and not to a directory.
>From QGI S server code:
  // Initialize the authentication system
  //   creates or uses qgis-auth.db in ~/.qgis3/ or directory defined by
QGIS_AUTH_DB_DIR_PATH env variable
  //   set the master password as first line of file defined by
QGIS_AUTH_PASSWORD_FILE env variable
  //   (QGIS_AUTH_PASSWORD_FILE variable removed from environment after
accessing)
Hope it helps.
> In a local test my qgs project file opens the postgis Layers with the
> authcfg in qgis-auth.db
> Calling a layer as wms, QGIS Server log shows:
> CRITICAL Server[17067]: Layer(s) … not valid
> My environmental vars are not mentioned by QGIS Server log, instead it
> shows
> Auth DB PATH: //.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
> Has anyone a running configuration for QGIS Server using qgis-auth.db ??
> Mit freundlichen Grüßen
> Im Auftrag
> *Stefan Overkamp *
> Team Geodaten-Technik
> *Referat Geoinformation und Raumbeobachtung*
> Kronprinzenstraße 6
> 45128 Essen
> T:
> F:
> +49 201 2069-700
> +49 201 2069-369
> *Regionalverband Ruhr *
> Die Regionaldirektorin
> Kronprinzenstraße 35
> 45128 Essen
> T: +49 201 2069-0
> F: +49 201 2069-500
> www.rvr.ruhr
> Postfach 10 32 64 | 45032 Essen
> Steuernummer: 112/5797/0116 | USt.-ldNr.: DE 173867500
> Diese E-Mail könnte vertrauliche und/oder rechtlich geschützte
> Informationen enthalten. Wenn Sie nicht der richtige Adressat sind oder
> diese E- Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die
> unbefugte Weitergabe dieser E-Mail sind nicht gestattet.
> This e-mail may contain confidential and/or privileged information. If you
> are not the intended recipient (or have received this e-mail in error)
> please notify the sender immediately and destroy this e-mail. Any
> unauthorised copying, disclosure or distribution of the material in this
> e-mail is strictly forbidden.
> Qgis-user mailing list
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190625/59bd00e8/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190625/59bd00e8/attachment.jpg>
