[Qgis-user] applying qml to vector layer with pyqgis
    Francisco Pérez Sampayo
    fpsampayo at gmail.com
    Fri Mar  1 00:44:26 PST 2019
El vie., 1 mar. 2019 a las 9:41, Stefan Giese (<Stefan.Giese at wheregroup.com>)
escribió:
> Hello Reginald,
> strange, because for me it works having the qml and shapefile in the
> same directory with the same names (QGIS 3.6, Windows).
Same for me on 3.6. All works fine.
> Best regards
> Stefan
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> FOSS Academy Kompaktkurs "Winterschule 2019"
> Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
> https://foss-academy.com/kompaktkurse
> WhereGroup GmbH & Co. KG
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Am 01.03.2019 um 09:23 schrieb Reginald:
> > Hello list,
> > I have a whole series of shapefiles and qml files residing in the same
> > directory.
> > The shapefiles and the qmlfiles have according names: eg.
> > Adp36007.shp --> Adp36007.qml
> > I have read somewhere that those qml files would be applied automaticaly
> > when I load the shapefiles in the map. That doesn't happen.
> > So I wrote a quick script:
> > from qgis.PyQt.QtCore import *
> > from qgis.PyQt.QtGui import *
> > from qgis.PyQt.QtWidgets import *
> > from qgis.utils import iface
> > from qgis.core import *
> > layers = [layer for layer in QgsProject.instance().mapLayers().values()]
> > dirname = "F:/GRB/Recent/"
> > for lay in layers:
> >      qmlname = dirname + lay.name() + ".qml"
> >      lay.loadNamedStyle(qmlname)
> >      print("processed " + qmlname)
> >      lay.triggerRepaint()
> > print("done")
> > But that doesn't work. Applying the qml via the GUI works so there is
> > nothing wrong with the qml files.
> > Has anything changed in QGIS 3.4 with loadNamedStyle?
> > Regards,
> > Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190301/effcfeeb/attachment.html>
