[Qgis-user] change default webbrowser in qgis3 settings?
    Groene Bij
    mail at groenebij.nl
    Fri Mar  1 01:35:29 PST 2019
Hi Richard,
Using your line in the Python Console I get the following message:
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\code.py", line 90, in runcode
    exec(code, self.locals)
  File "<input>", line 1, in <module>
TypeError: openUrl(QUrl): argument 1 has unexpected type 'str'
I am using 3.4.5 LTR
Greetings,
Jeroen
-----Oorspronkelijk bericht-----
Van: Qgis-user <qgis-user-bounces at lists.osgeo.org> Namens Richard Duivenvoorde
Verzonden: maandag 25 februari 2019 22:08
Aan: qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] change default webbrowser in qgis3 settings?
Hi Jeroen,
I'd say: create an issue in the repo of it:
https://github.com/tomchadwin/web2qgis/issues
I have some plugins which opened an url or file in a browser, and then used default Qt-machinery, something like:
QDesktopServices.openUrl('http://qgis.org')
What happens if you use that in the Python Console? In your QGIS 3.
Does it open your preferred browser?
Or does it also open IE. If last, then maybe it is a Qt setting?
Regards,
On 25/02/2019 09.43, Groene Bij wrote:
> Hi all,
> I am sorry to repeat this question. I really hope someone can help.
> Today I did a clean install of 3.4.5 and exporting a map with the
> plugin qgis2web it still opens the webmap in IE. I don’t use IE,
> haven’t configured it and it is not my default webbrowser in Win10.
> Somehow, some setting in qgis 3 doesn’t use my default windows
> settings correctly.
> Qgis 2.18.28 doesn’t have this problem. I also did a clean install of
> 2.18.28 today, exported a map with the plugin and it opens in my
> default webbrowser which is Firefox.
> Is it a bug in 3.4.5?
> Is there a setting somewhere to change the webbrowser used?
> Gr.
> Jeroen
> *Van:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *Namens *Groene
> Bij
> *Verzonden:* maandag 11 februari 2019 17:10
> *Aan:* qgis-user at lists.osgeo.org
> *Onderwerp:* [Qgis-user] qgis3 uses IE as default browser on windows10?
> Hi,
> Is there a setting in qgis3 to change the default internet browser
> used by processes?
> For instance, qgis2web opens a webbrowser after exporting the webmap.
> In
> qgis2.18 my default browser Firefox was opened. Now, qgis3.4.4 it opens IE.
> According to Tom Chadwin (qgis2web) the plugin refers to a piece of
> Pyhton code when opening the webbrowser:
> The code which opens the browser when you export is:
> https://github.com/tomchadwin/qgis2web/blob/master/qgis2web/maindialog
> .py#L342
> It uses the Python webbrowsermodule:
> https://docs.python.org/3/library/webbrowser.html
> I have no experience with pyhon, so I hope there is a setting
> somewhere to choose my default browser. Besides that, I do hope qgis3
> will simply follow the default settings from the OS.
> Kind regards.
> Qgis-user mailing list
